This discussion topic has been answered Discussion topic: Sky stream problems
Message posted on 12 Sep 2025 08:15 PM
Sky stream keeps dropping WiFi.... is this a common problem? Anyone else have this issue?
Message posted on 13 Sep 2025 06:42 AM
Your Sky Stream should not be doing this.
Its most probably an interference type issue on your local network.
Have a read of my generic listing below I often post on here, that some ups some of the local network and interference issues and possible solutions, that have helped others in the past and provide a more stable environment.
Do a reboot of your broadband router, with your Sky Stream puck/s in standby mode.
Having a good local network broadband reach is key to Sky Stream.
Not just broadband speed to your house and router, but for your local network supply via wifi or ethernet, that can be affected in a busy household.
Best way to test is via a network speed test on each of your Pucks.
Launch Netflix on your pucks (you do not need to be logged into it, if you do not use netflix) and scroll down the left menu to Get help.
Choose Check Network.
Would suggest running the test a handful of times, over say a half hour period during tests that will show any noticeable fluctuation in speed.
What is your speed for each puck?
Also, it may be suffering from interference, the puck much like a Sky Q box can for some customers suffer from this at times. More often seen as an intermittent blip.
Not always a cure, but the following may help to resolve;
Make sure you have a good 6-8 inches free on all sides of the puck.
Do not stack the puck on top of any other device.
Best not to sit it on a glass shelf. Wood is generally the best.
Make sure the puck is in the open, not tucked away in a cabinet or sat directly behind the TV.
Make sure you have no other devices that can cause interference closeby, like cordless phones, radiators, baby monitors, smart meter in home displays, microwaves and the like.
You should be using the Sky supplied hdmi cable or a high speed equivalent one.
Plus, change both your pucks to following recommended settings set in Settings>
Turn wifi OFF under Network if connected via ethernet.
Set Network standby mode to ON and Overnight power saving to OFF.
Would suggest at least once a week, to do a settings restart;
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete
