Discussion topic: Sky stream problem
Message posted on 09 Jun 2026 05:09 PM
Sky stream problem
We have 3 pucks. 1 puck is giving problems. Started about 2 weeks ago. Picture freezing and pixelated. Also sound dropping out. Unplugging and rebooting solves problem for a while but problem returns. We are now rebooting multiple times per day, problem seems to be getting worse. Also have rebooted our router.
Message posted on 09 Jun 2026 06:18 PM
Re: Sky stream problem
@Tafw wrote:We have 3 pucks. 1 puck is giving problems. Started about 2 weeks ago. Picture freezing and pixelated. Also sound dropping out. Unplugging and rebooting solves problem for a while but problem returns. We are now rebooting multiple times per day, problem seems to be getting worse. Also have rebooted our router.
Have you tried switching the pucks around, and seeing if the problematic puck is causing issues in other locations in your property? If it does you know the puck is faulty, if it doesn't and a previously working puck doesn't work in the same location then it will likely be down to poor network conenctivity to that part of your property.
