Discussion topic: Sky stream playlist and continue watching for Discovery+
This message was authored by: dilbert999999
Since HBO Max launched I have 2 issues relating to Discovery +......
1. Any programmes I had in my playlist that were on Discovery + have now changed to other channels if available or disappeared completely. Still all exist in Discovery+ app in my stuff.
2. The Discovery+ app still has all my shows in it's continue watching but nothing now shows up in sky stream continue watching
is anyone else having these issues?
 Anyone know what's happened?
Re: Sky stream playlist and continue watching for Discovery+
Hi @dilbert999999 I currently only have 1 Discovery+ programme in my continue watching as it is working exactly as expected.  I watched an episode last night and the next one has appeared in my CW rail.
Have you tried refreshing your Apps by going to Settings >System Management > Resets & updates > Apps refresh?  This process can take a few hours so I tend to do it overnight.  It helps clear minor glitches so might help in your case.  As the process is carried out in the background you can still use your puck whilst the process is running.
Avatar for dilbert999999
Hi
Thanks for the suggestion. I tried that and I've also done a full reboot of the puck afterwards but still the same
