Discussion topic: Sky stream pixelated
This message was authored by: Joey_rara
Message posted on 08 Nov 2024 09:35 PM
been watching tv all night and every few seconds it's pixelated. Have reset router and puk.
This message was authored by: martswain
Message posted on 09 Nov 2024 06:29 AM
Re: Sky stream pixelated
If it is happening on all channels then it's likely to be a broadband speed issue.
What speed does the Netflix checker report?
WiFi connections between puck and router can be affected by interference and weak signals at longer distances.
Try connecting by ethernet and if doing so, disable WiFi on the puck.
