07 Dec 2023 12:29 PM
Trying to set up sky steam it played for about 2minutes now it won't play on any channel
07 Dec 2023 12:42 PM
Posted by a Superuser, not a Sky employee. Find out more@ChrisH21 it might need a reboot. Turn it off at the plug for 30 seconds before turning it back on. This is why common after the initial setup, i think its mainly the result of the initial software update it does.
If it still has issues it may be the internet connection its getting. How have you setup the internet WIFI or ethernet?
