14 May 2023 03:35 PM
14 May 2023 04:30 PM - last edited: 14 May 2023 04:31 PM
@alison01656 wrote:
Turned sky stream on, but get a invalid format on screen
@alison01656 The first thing to do is a reboot of the puck. Switch it off at the plug socket for 30 seconds before switching it back on again. I will take about a minute to reboot.
If that doesn't help have a look at the trouble shooting guide at the link below:
Follow the troubleshooting steps and try the recovery process (step 4 I think) which might also help. If this did not resolve the issue click on the button Yes, I still need help click the phone icons and it will taker you to a phone number to use to contact Sky.
Good luck 🤞
Good luck 🤞
14 May 2023 04:43 PM
Posted by a Superuser, not a Sky employee. Find out more@alison01656If you are not using UHD change the output in settings to 1080i rather than "auto" this may help.
14 May 2023 08:11 PM
All sorted now, switched off power for a few minutes, now working
14 May 2023 09:27 PM
Posted by a Superuser, not a Sky employee. Find out more@alison01656 That's great news, I'm glad it sorted out your issue 😀
As a general rule it is the first thing to do if your system starts to misbehave but of course it doens't work for every situation.
