Discussion topic: Sky stream keeps freezing and won't switch off
This message was authored by: Alexmac31
My sky stream puck freezes and won't switch off at least 10 times a day it's not broadband speed I'm on Vodafone 910mbps and I have three other picks that work perfect I've tried reset it doesn't help amd the puck is all updated
This message was authored by: peter-marlow+1966
Re: Sky stream keeps freezing and won't switch off
May be a faulty  puck if your  other 3 are working  fine
P c marlow
Avatar for Alexmac31
That's what I'm thinking
I would give sky a call, when you do and the automated  system  says  we have sent you a link  would you like to use it say no and you will get to talk to someone at sky about  your issues
P c marlow
This message was authored by: Hunter2660
Just to be sure, swap the dodgy puck with one of the others and see if the issue persists on that puck or continues on the swapped puck.
I have done and it works fine till I try the dodgy one again
It could also be that where that puck is the wifi  may not be getting  the strong  signal  aswell
P c marlow
Also on the puck you are having problems with  go to Netflix open  the app scroll down  to help open  that go to check  my  network  and run a test  to see what speed that puck is getting
P c marlow
