Discussion topic: Sky stream keeps dropping out
Message posted on 17 Dec 2025 09:00 PM
Message posted on 17 Dec 2025 09:42 PM
Re: Sky stream keeps dropping out
@Bellabim it could be a fault with the puck but its worth checking the WiFi signal strength the puck is feceiving by looking stvthe indicatiin in the Settings/Network menu. Stream oucks need sufficent bandwidth butvas important is stablecdignal free from interference.
Message posted on 17 Dec 2025 11:58 PM
@Bellabim Are you connected via an Ethernet cable? If not does your router have a clear line of sight to your puck with nothing in the way.and is your puck and router clear of any objects near them? This can often effect the signal.
