Discussion topic: Sky stream keeps cutting out
This message was authored by Sauzee71 This message was authored by: Sauzee71
Will be watching something on Sky stream when the connection will just cut out/puck switches off with no warning. No issues with broadband service. Any ideas why this happens?
This message was authored by Padam_Padam This message was authored by: Padam_Padam
Re: Sky stream keeps cutting out
What is your broadband speed? Are you connected via WiFi or Ethernet?
Sauzee71
Wi-Fi, speeds of 895Mb/s
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
Did you run the speed test from the Stream puck and that is the only way to determine what speed the puck is getting?
To run from the puck you need to open Netflix, go the Get Help and then Check My Network.
Sky Stream and Sky Broadband customer
