Discussion topic: Sky stream issues
This message was authored by: Lyn32
Sky stream issues
My sky stream keeps buffering all the time is there anything I can do or buy to make it stop doing this please
thankyou
Re: Sky stream issues
thankyou
Improve your broadband speed and quality would be the first line of attack.
Check what speed your puck is actually receiving by running a network check from the get help menu within the Netflix app. You need a minimum of 25Mbps constantly for Stream to function with any sort of reliability.
Avatar for Lyn32
Thankyou and what can I do if I don't have that minimum spread please
This message was authored by: Super+Anthony
It's probably the inadequate puck which needs severe updating and Sky to admit it
(Please Note: I am Neurodivergent )
If you don't have that minimum speed then it's pointless having Sky Stream.
SkyOS which runs on it is server-based so needs a constant fast and stable connection. If you cannot provide it the you're better getting a different TV service.
