Discussion topic: Sky stream issues
This message was authored by: jsumner
Sky stream issues
Hi. Having constant issues with sky stream. Puck in the kitchen drops off and says no WiFi network randomly even though the WiFi is working fine on other devices. The one in the living room is connected by Ethernet cable but gets regular pixelation and needs a reset that sorts it. I must be resetting and reconnecting virtually every day.
I have the Sky max hub and use deco WiFi extenders. Any ideas? Thanks
This message was authored by: Mr+Flibbles+86
Re: Sky stream issues
This message was authored by: Kath470
Thank you
