5
This discussion topic has been answered Discussion topic: Sky stream connection
This message was authored by: ABsky
I have a 150mbps full fibre connection from a company called Zzoomm.  As it enters my home, there is a separate modem and then a powerful router which actually gives about 190 mbps in every room.
If I wanted to purchase Sky stream, would I need the small square sky box or just the pucks working solely from wifi and with no Ethernet cables?
This message was authored by: MarkGoldsmith Answer
Re: Sky stream connection
It should work perfectly fine using WIFI.
Its just some customers find a better experience using an ethernet cable due to local interference causing a weaker and unstable Wifi connection.
This message was authored by: Nigelb1972
Just the Puck as Stream should work on any internet connection that meets the required specs
Avatar for ABsky
That's great guys.  Thank you for your help
This message was authored by: Mandysky2024
The cable is loose
@Mandysky2024 wrote:
The cable is loose
Which cable?
