Discussion topic: Sky stream and universal remote control
This message was authored by: kdp99
I have just got sky stream and have it working OK with the supplied remote. I use a universal system remote control with my system. I know my way around universal remotes very well.
I had already got the Universal remote set up for SkyQ. I find that with the universal remote it that the Puck will ONLY turn on with the power command. Once it is on it will not respond to the any button (even power off). I  then tried to learn the commands from the puck to my universal, it does not seem to be getting any infra red signal to learn.
I conclude that once on, the puck is doing something odd with its remote settings ? Any ideas ? IK know others have used universal remotes with SKy Q and Sky stream
  Thanks in advance
k
Avatar for kdp99
Level 3 icon
Re: Sky stream and universal remote control
Bit of an update. Turned off bluetooth and have learn't all commands except power, which still does not seem to be sending IR command even with bluetooth off.
I can use home to turm it on, but I really hope there is a way to turn it off via IR on a universal remote control ?
k
Avatar for kdp99
Level 3 icon
I have found IR codes below for everything except power, tested one (three dots), and it works fine.
https://groups.io/g/crestron/topic/sky_stream/101950374?dir=asc
k
This message was authored by: Stok3sy
Hi what universal remote do you use?
