Discussion topic: Sky puck technical fault
Message posted on 24 Oct 2024 12:42 PM
Message posted on 24 Oct 2024 01:05 PM - last edited: 24 Oct 2024 01:19 PM
Re: Sky puck technical fault
@Phill+cooper How is the stream puck connecting to your router? As this issue is typical of poor wifi being received at the puck, and wifi can be prone to interference.
What speed is the puck getting from the hub? Open the netflix app, go to Get Help, run the connection test, what speed is being reported.
Message posted on 24 Oct 2024 01:17 PM
Netflix says connection speed 286.12mbps
Message posted on 24 Oct 2024 01:21 PM
@Phill+cooper If this is the speed on the netflix app on the puck it would sugeest speed isn't an issue, however when the issue does occur it may be worth running the speed check again to see if there is a sudden drop in speed.
Message posted on 24 Oct 2024 02:56 PM
Who is your ISP?
Message posted on 24 Oct 2024 03:01 PM
What is a isp?
Message posted on 24 Oct 2024 03:04 PM
Internet Service Provider😉
Message posted on 24 Oct 2024 04:49 PM
Arr right its sky
