Discussion topic: Sky puck/router issues
This message was authored by: Brynf
I am having issues where my router is resetting up to 20 times a day. It is possible this reset is being triggered by radio interference. Is it possible that the Puck is causing this as the issue timing started around the same time as I swapped to the puck
Re: Sky puck/router issues
Highly unlikely the puck can cause such issues, however have you tried using ethernet from the puck to your router
Who supplies your broadband?
Does the router reset when Puck is powered off at the plug?
Avatar for Brynf
No, router resets at random times. Possible cause is radio wave interference caused by any electrical device.  Just trying to see and eliminate various de ices in the home
