Discussion topic: Sky puck problems
Message posted on 17 Jan 2025 10:20 PM
Sky puck problems
Hi
quite frequently our sky puck doesn't fully turn on menus are there but no sound or pictures. We have to reboot several times before we can watch Tv. It's intermittent problem.puck was changed last month. Also our sound is getting quieter
any solutions
Message posted on 18 Jan 2025 12:41 PM
Re: Sky puck problems
Hi @Grouse1
What is your broadband speed? Sky stream needs 25Mbps for HD and 30Mbps for UHD. You can check the speed your getting by opening netflix going to the menu and down to get help? And then selecting connection check.
But your symptoms are typical of poor connectivity.
MikeAlanR
Message posted on 18 Jan 2025 01:50 PM
hi
the connection is via Ethernet and is currently 85mbs or via Wi-Fi it's 287 mbs
more than adequate
any other ideas are welcome
Message posted on 18 Jan 2025 01:57 PM
The SKY IVR advises that there is a known issue, don't spend the afternoon messing around going through self-support advice from others. SKY acknowledges that there is an issue and engineering are looking it.
Message posted on 20 Jan 2025 08:35 AM
