Discussion topic: Sky puck picture zoomed
Message posted on 13 Feb 2026 11:58 AM
Picture is zoomed on start up having to reboot constantly
Message posted on 13 Feb 2026 12:29 PM
Re: Sky puck picture zoomed
That is probably more to do with your TV, than Sky Stream.
Two things to try.
Try changing your TV aspect ratio or 'zoom' level, go into your TV settings and look under picture settings.
You could also try going into the Sky Stream puck settings under Picture and Sound>Picture resolution and set it to 1080p
Message posted on 12 Sep 2026 09:04 PM
I have exactly same issue, nothing to do with aspect ratio as all other apps, tv totally fine.
Message posted on 13 Sep 2026 07:44 AM
@Rol1 youe TV can have different settings for each input so your assumption it must be the puck is not true. Check the screen settings with your TV remote while Sky stream is running. Sky stream programming in normal aspect ratios with black bars at thecdside or top and bottom as required.
