Discussion topic: Sky puck not working
This message was authored by: Conways
The white light is on by nothing is in the screen. The tv is on but the sky won't connect
This message was authored by: CoffeeDrinker
Re: Sky puck not working
Are you hearing any sound if you try and use the Sky Stream remote control? If not, chances are your TV hasn't;t automatically switched to use the HDMI input your Sky Stream is on. If so you might need to use your TV remote to change the input to the right HDMI port.
If you are hearing sound when you use the Sky Stream remote then it may be outputting too high a resolution (2160p) than your TV can handle. Are you using Sky Stream with a 4K TV or an older/smaller 1080 HD TV?
Lounge: Sky Glass gen 2 65” volcanic grey, Denon X3500H AVR. M&K K Series 5.1.2 speakers, PS5 Pro, Apple TV 4K, Sony X800 M2 4K player.
Bedroom: Sky Glass gen 1 43” dusky pink, Apple TV 4K.
This message was authored by: Stephen+Mourton
@Conways   Have tried the old turn it off and turn it on trick?  If not unplug the puck from the mains, wait at least 30 seconds then plug it back in again and wait for it to reload.
@Conways
Can you perform the recovery procedure as shown on step 4 of this Sky help article;
https://www.sky.com/help/sky-tv/sky-tv-stream/fixing-a-problem-sky-stream/fixing-sky-glass-sky-strea...
