Discussion topic: Sky puck constantly freezing
This message was authored by: Rec6
Sky puck constantly freezing driving us insane never had a problem with sky q . We have rebooted , checked internet speeds nothing works
Re: Sky puck constantly freezing
Hi @Rec6
You can't compare stream to Q. Q delivery is via satellite and Stream is via broadband.
You need 25Mbps for HD and 30Mbps for UHD. What you are describing is usually a symptom of poor WiFi connectivity or broadband speed. What speed is your broadband and what speed is your puck getting? You can check this by running a speed test in netflix. (Open left hand menu > get help? > Connection check).
MikeAlanR
This message was authored by: Dave1234567891
Absolute nonsense, I have had issues since I got the stupid pucks, sold the dream! Both pucks lip sync issues, skys solution dumb down your sound settings. Not the pucks are freezing. I'm using Ethernet with full fibre 900. Netflix says my connection speed is 880mbps. So NO I do not accept the issue is broadband speed. The issue is with the pucks. Sky need to sort it out or let people out of their contracts to go back to Virgin.
Avatar for Rec6
Totally agree it's the absolute worst ! Do you know if sky glass has the same issue's
This message was authored by: Jporch316
You can't be using Ethernet - they are only 100mbs adapters in glass and pucks .
if you are using Ethernet you have to turn off wifi in the pucks settings
Ethernet to both the puck and TV. WiFi is turned off. Always use the TV apps because through sky I get lip sync issues.
