Discussion topic: Sky puck connection issues
This message was authored by: djcutmore76
Our sky puck is having trouble connecting to the internet.  We have a good connection and then it will disconnect for no reason and say 'no signal'.  I've tried resetting the box several times but it is not consistent and so bad that I am unable to watch anything on sky and considering cancelling my subscription...any help
or ideas welcome...thanks!
This message was authored by: billx
Re: Sky puck connection issues
The puck does not have a speed or signal test, so no way to say 'it has a good connection'.
workaround is to go to netflix on the puck, in the netflix settings somewhere, you will find a speed test.
I assume you are connecting via wi-fi. Try connecting directly to the routher with an Ethernet cable.
What speed is your bb when running a speed test?
How many uses on your bb and how heavy is their data use?
Stream needs a good 25mb minimum, all to itself, to work.
I don't work for sky, receive any gratuities or discounts. They do however pay me in badges 🐵
If I have helped, please click the thumb 🐵
IT & Telecoms professional, Bsc, Hsc 33+ years experience. Hands-on, installation, maintenance & troubleshooting
Qualified (Level 3) Electrical Engineer
Sky from Astra 1989 > sky digital > Sky Hd > Sky Q
