Discussion topic: Sky puck and connection
Message posted on 05 Oct 2026 09:30 PM
Message posted on 05 Oct 2026 09:36 PM
Re: Sky puck and connection
Hi @StaceyU
First you need to check if your pucks are getting the minimum required speeds. You say your broadband is going slow but what broadband speed do you get? Next is check the speed on your pucks. You can do this in netflix (Profile pic > get help > connectivity check).
It will be worth running this multiple times and taking an average. The other thing to you can try to decide if it is a hardware issue, is swap the working one with a misbehaving one. If the previously working puck starts playing up it is likely local environment.
If you do need to swap a puck you will need to call sky as we are fellow customers here on the community.
MikeAlanR
