Discussion topic: Sky pick keeps freezing
This message was authored by: Bigtoe69
Message posted on 08 Aug 2025 10:55 AM
My sky pick keeps freezing l, I have tried updating and resetting but still keeps happening
Find out more
Message posted on 08 Aug 2025 11:00 AM
Re: Sky pick keeps freezing
Hi @Bigtoe69
This usually points to poor connectivity. Sky say you need 25Mbps for HD and 30Mbps for UHD. What speed is your Sky Glass receiving? You can test this by opening netflix and going to Get help > connection check.
You may have better luck using ethernet or home plugs (but remember to turn WiFi off in your glass settings).
MikeAlanR
