Discussion topic: Sky Stream
Message posted on 23 Oct 2026 04:53 PM
Sky Stream
Who has Sky Stream and is it worth it
Message posted on 23 Oct 2026 05:10 PM
Re: Sky Stream
@Lincatseyes Have you looked at any of the posts on this board?
Message posted on 23 Oct 2026 05:22 PM - last edited: 23 Oct 2026 05:25 PM
Re: Sky Stream
A question that can have no answer.
Question is, is it worth it for you?
I love the interface, brings all the streaming services into one place, prime, netflix, itvx, disney+ etc
so you have just one app to open and can see all of the stuff that you are currently watching all neatly lined upin 'Your Playlist' and as a new epsode or series of a programme you have added to your playlust is released, it appears in your playlist as the first item.
Due to s many content producers having their own streaming service & not supplying sky, sky have had to bundle disney+ discovery+, hulo etc. So these are all in one place, on sky stream. No having to keep hopping about from app to app.
You also get a discount for a netflix subscription.
I do not watch live tv, so stream is great to watch everything on demand or on a ketchup service (live tv is available via the epg)
remote is voice activated, so just say what yoy want 'skip ten minutes' 'play startrek' etc.
Whilst the apps disney, netflix etc allow you to view from anywhere, sadly the sky T&C state you can only watch from your home location.
sky monitor your ip address, so if it changes too often, you get sent a snot-o-gram.
Yes it is expensive, so it depends how much use you get from it.
Whilst some streamers are pay per month & cancel anytime, sky stiches you up with a long contract and mid-term price hikes.
If I have helped, please click the thumb 🐵
IT & Telecoms professional, Bsc, Hsc 33+ years experience. Hands-on, installation, maintenance & troubleshooting
Qualified (Level 3) Electrical Engineer
Sky from Astra 1989 > sky digital > Sky Hd > Sky Q
Message posted on 24 Oct 2026 02:32 PM - last edited: 24 Oct 2026 02:57 PM
Re: Sky Stream
@Lincatseyes @billx Has pretty much summed it up really.
(& yes i had a "Snot-0-Gram" too as i forgot to add my pucks to my router side VPNs exeptions 😂😂)
I would say Sky Stream is like Marmite Some (like me) love it & others hate it.
The Pros (For Me At Leased)
(1) like the clean interface & pretty much everything you need in one box
(2) Generally i find the user interface & system on the whole intutitive & easy to use
(3) Really like the remote its laid out well & the voice commands work really well for me
(4) One great thing is all the billing & account things i need are on the box (Most of the OS is actually on a server)
(5) Prices are all subjective for me i have pretty much everything going exept sport channels & where as i do pay a premium i think being im home a lot & use it a lot im getting what i pay for , there are all sorts of packages to suit all needs & budgets.
(6) Picture & sound quality is great
(7) Easy to set up
(8) Small footprint
(9) No dish or antenna required at all
(10) Great supply of on demand content & 3rd party streaming services.
Cons (for some not others)
(1) Internet requirements - wile reletively low speeds are required for sky stream
I would always reccomend some kind of full fibre FTTP (150Mbps & Up) as Yes you can use it with copper connections (FTTC) , they generally top out at about 80Mbps & an average of only 67Mbps , thats not a lot of headroom for other devices being used , potential loss due to wifi etc & also multiple pucks being used at same time , i dont know about the wifi as i dont use it but as far as the Ethernet connection goes its is only a 10\100 connection (100Mbps max) , so i would say although it doesnt need it allow the full 100 for the pucks & at leased 50mbps for your other devices , phones , tablets , PCs etc , now PERSONALLY i would allow more than 50mbps i wouldnt even think about it on anything less than 300Mbps UNLESS you live alone & are only likely to be using say 1 device at a time , other devices need the overhead & some devices will take the entire lot a torrent thats uncapped , an uncapped direct download etc so it all depends on living & usage situations , im convinced the route cause of a lot of the "issues" i see here are down to congested internet & certain IPV6 settings in certain routers (My own routers IPV6 caused me a lot of issues)
(2) While customer tech support do thier best it should be known that for the most part sky stream is at its core a "self help" system , users are encouraged to troubleshoot networks & other problems by use of self help links & posts here & elswhere & user fault finding
(great for some like me but could be a con for others)
(3) No "Traditional Recoding" unlike sky q there is no traditional hard drive recoding
(although for me playlists are more than an adequate replacement , for others maybe not so ?)
(4) The obvious elephant in the room , No internet ?.....No Sky , it is what it is & is true of any streaming service.
(5) Its both a Pro & a Con (for some but not me) , the majority of what you do , see , view on the puck is acually on a server even the majority of its OS is actually sstreamed & not on the puck so this goes back to point (1) on internet speed & most importantly stability etc.
2x Sky Stream Pucks | 2x Hisense 55" UHD | 1x Sony 42" HD
Sky Ultimate + Cinema + Whole Home | Max/Netflix/P+/Disney+
(Just a customer helping customers. I do not work for Sky.)
Message posted on 24 Oct 2026 06:28 PM
Re: Sky Stream
@billx Glass etc is great plus I'd never watch it away from mine otherwise I'd get caught out viewing it elsewhere If I logged in 😂
