8
This discussion topic has been answered Discussion topic: Sky Stream when I am a Sky Q Customer
This message was authored by: MartinD1969
I am currently a sky Q customer , I have 3 Sky Q mini boxes in various rooms but in one I cannot hide the box easily - The simple solution seems to be get a Sky Stream Puck, however that doesn't seem available to me online as an existing Sky Q customer - is there a reason that I cannot use my full package (Cinema, Netflix, Sports etc) across both platforms ?
This message was authored by: MarkGoldsmith Answer
Re: Sky Stream when I am a Sky Q Customer
Because they are two platforms. You can't mixed the streaming platform with the satellite based platform as there are differences between the two. Not only are the way the platforms operate and mare delivered diffferent the list of available channels and TV packs offered on the services differ as well.
Sky allow you to have the satellite platform or the streaming platform at an address they can't be mixed, any order for Sky stream will lead to Sky having to cancel Sky Q at that address.
Avatar for MartinD1969
Thank you - that is what I suspected but I had assumed that Sky Glass too was a different platform to Sky Q - Apparently that is a possible combination.
Is Sky Glass not simply a TV with and embedded Sky Stream OS ?
Yes, Sky Glass is a TV with the same SkyOS that runs on a Stream puck, but again, it's a different subscription model to Sky Q.
You cannot mix a Sky Q and a Sky Stream/Glass subscription - it's one or the other.
You can buy a second hand Sky Glass TV and connect an existing Sky Q box to it via HDMI, but if you buy a new Sky Glass TV from Sky you have to start a streaming TV subscription with them which will automatically cancel any existing Sky Q  subscription.
Really usful thank you - as a Sky Q Customer, online I am prevented from purchasing Stream - because of the limitations outlined in the reponses. But I am NOT prevented from purchasing Sky Glass - or warned that it will cance my Sky Q subscription - hence my confusion
thanks all
I believe at some point in the order journey it should tell you it would cancel your Sky Q subscription ( however its possible if it does do this it won't until you checkout the order).
Its always best for existing sateliiete subscribers to phone call to arrange the switch to Glass/Stream ( indeed for Stream you have to call Sky to do this).
This message was authored by: djh1697
You should try Apple TV 4th generation with the TV launcher app. It uses your SkyGo login to allow you to stream films; you can load Netflix, Disney, Paramount+ and other applications without the need to pay for a SkyQ mini box.
This message was authored by: DaveDrizen
That is correct  originally the puck was only available to Sky glass subscribers so they could have the streaming service on an excisting tv. Then Sky decided to make them. available to subscribers without having to get a Sky glass tv. That when the Sky stream service started.
@DaveDrizen
Stream pucks launched alongside Glass television sets in October 2021.  Stream became a product by itself exactly one year later: this was presumably always the plan rather than an afterthought.  Realistically a product as profoundly average as the Gen 1 Glass was never going to dominate the television marketplace, and Sky wasn't going to be without a box to attach to other brand sets.
