This discussion topic has been answered Discussion topic: Sky Stream remote: volume controls inverted when using soundbar.
Message posted on 13 Feb 2025 02:59 PM
Hello,
Set-up Sky Stream today including setting-up remote to control volume on Bose soundbar. Worked through the available options offered by the set-up and chose the first option that seemed to work. Unfortunately, the sound control is inverted. Pressing up volume on the remote actually turns the volume down. How can I get into the settings and try another option?
Message posted on 26 Apr 2025 09:03 AM
Hello,
Yes!
The installed options did not work for my soundbar. I went to the Bose support website, https://www.bose.co.uk/en_gb/support/products, selected my soundbar, selected manuals and downlaods then the appropriate remote codes booklet. I then input the codes manually in the Sky Stream settings.
I went for the 4 digit codes and one worked. Apparently, you can tell whether you need 4 or 5 digits buy looking at the Bose remote. Remove the battery cover and find the serial number. The last two digits '20' or '30' define how many digits you need to programme the remote.
Message posted on 13 Feb 2025 04:44 PM
Re: Sky Stream remote: volume controls inverted when using soundbar.
hi @Anonymous
Press 7 & 9 together for three seconds to reset your remote.
Pree 1 & 3 together for three seconnds to go through the bluetooth setup.
You should see the "connected" message and same onscreen prompts as before.
MikeAlanR
Message posted on 13 Feb 2025 07:56 PM
Thank you. Much appreciated.
Message posted on 25 Apr 2025 10:39 PM
Did you get this resolved? I'm having the same issue with my bose tv speaker
Hello,
Yes!
Message posted on 26 Apr 2025 09:42 AM
Oh Brilliant! Thank you for the quick response. I will try that today!
