Discussion topic: Sky Stream puck PSU to large to fit behind a wall mounted TV
Message posted on 24 Jun 2024 01:52 PM
I have just moved from Sky Q to Sky Stream and the PSU that comes with eack Puck is a very poor design as the cable sticks out from the plug horizontally and not vertically or at right angles to the plug. The affect of this is if you have a wall mounted TV with the mains socket behind the TV the TV will nolonger fit flush to the wall or as in my case at all. Sky have advised that they do not supply an alternative smaler or rightangle PSU so has anyone found a solution to this?.
Message posted on 24 Jun 2024 02:49 PM
Re: Sky Stream puck PSU to large to fit behind a wall mounted TV
You'll find previous posts discussing the use of a suitably powerful USB plug with a USB to barrel jack cable.
However, on all loaned pucks (acquired after February 23rd 2023) the official answer has to be that only the Sky supplied power adapter should be used.
