Discussion topic: Sky Stream not finding any WiFi networks
This message was authored by: Ryan1509
Hi,
my sky stream box started playing up over the weekend after my WiFi went down. It randomly wouldn't accept my WiFi password so I did a compete factory reset and now it won't even find ANY available WiFi networks for me to connect.
any ideas?
Re: Sky Stream not finding any WiFi networks
Hi @Ryan1509
Are you trying to set it up again? Factory resets are usually an option of last resort and only recommend when directed by sky.
Try the advice here: https://www.sky.com/help/articles/connect-tv-help-sky-glass-sky-stream-puck
Or try using an ethernet cable (just to complete setup) and then try reconnecting to WiFi.
Failing this you will need to call sky.
MikeAlanR
