Discussion topic: Sky Stream keeps going into Stand by.
Message posted on 04 Jun 2025 06:21 PM
A friend who is not technical at all has just got a Sky Stream box after my recommendation. We tried getting it up and running last week, but it works for about a minute then switches off. I suggested he got a booster for his WIFI which he has... but the same is happening. I don't know if the TV is bringing the box down or visa vesa. TV hasn't exhibited this before on COAX.
No lights on the front of the box, but white LED under front of box is on when the box is working but goes off and TV goes into standby.
Internet signal is strong. but TV is probably 10 years old... trying to run Steam box through HDMI 1
Anyone got any ideas please?
Message posted on 04 Jun 2025 08:37 PM
Re: Sky Stream keeps going into Stand by.
@Chris546 wrote:A friend who is not technical at all has just got a Sky Stream box after my recommendation. We tried getting it up and running last week, but it works for about a minute then switches off. I suggested he got a booster for his WIFI which he has... but the same is happening. I don't know if the TV is bringing the box down or visa vesa. TV hasn't exhibited this before on COAX.
Are you able to try it on a different tv ? This will check if it's a faulty puck or it's the tv
Message posted on 04 Jun 2025 09:47 PM
I will try this later in the week, Thanks. Are there any known issues with certain makes?
Message posted on 04 Jun 2025 10:43 PM
@Chris546 wrote:I will try this later in the week, Thanks. Are there any known issues with certain makes?
Not to my knowledge.......i will escalate your post to the online sky support team as well. Please lookout for an invitation to chat on here .
Message posted on 04 Jun 2025 10:45 PM
Could also try a different halo port on the tv
and also try a different hdmi cable
Message posted on 04 Jun 2025 10:56 PM
I tried HDMI 1 & 2 no difference, I assumed cable would be ok as it's brand new out of the box... but will try
