Discussion topic: Sky Stream fighting with EE set top box
Message posted on 04 Jun 2026 05:15 PM
Have just activated Sky Stream using the new Sky puck but have now lost broadband connection in a separate room where an EE set top box is installed. No problems with EE previously. The activation seems to have triggered the loss of the broadband connection. Any ideas?
Message posted on 04 Jun 2026 05:27 PM - last edited: 04 Jun 2026 05:29 PM
Re: Sky Stream fighting with EE set top box
@Baffled3 wrote:Have just activated Sky Stream using the new Sky puck but have now lost broadband connection in a separate room where an EE set top box is installed. No problems with EE previously. The activation seems to have triggered the loss of the broadband connection. Any ideas?
Who is your broadband with? I assume EE but just want to double check.
Reason for asking is that the EE TV Box Pro and Edge will only work on BT/EE broadband as they use Multicast, unless you use an aerial in the Pro Box of course.
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Message posted on 04 Jun 2026 05:30 PM
Your EE box will use EE's multicast stream. Sky use Unicast. I'm not saying that is the problem, but it might help to hear how they are both connected
