272
Discussion topic: Sky Stream - Remote won’t turn on any of my pucks!
Locked
This message was authored by EranuUvavu This message was authored by: EranuUvavu
Re: Sky Stream - Remote won’t turn on any of my pucks!
this is a very common scenario of using the remote to switch back on the puck.
you would have thought that they would want to test that....
This message was authored by Jporch316 This message was authored by: Jporch316
Guys just to point out that this is an issue that seems to be only affecting new units received in the last 3 weeks or so. As a general rule in the last 2 and a bit years this has not been an issue.
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
This message was authored by Kempston This message was authored by: Kempston
@Jporch316
The concern is if this is a hardware issue, and not something that can be resolved with a firmware update. Will Sky commit to replacing units if it turns out to be a bad batch of hardware or will they even officially accept it's a problem?
@Kempston wrote:
@Jporch316
I can only give an example of about 10 months ago where there was a bad batch of remotes that didn't work when delivered. Sky replaced them all. Fingers crossed an update will fix the issue.
Can I suggest people check again regarding the claims that IR doesn't work to turn on the pucks when paired via Bluetooth. There must be something that is causing mine to work under these circumstances, I've checked again and my paired remote absolutely is turning on my puck via IR where it isn't via bluetooth.
Reset your puck. Reset your remote. Set everything up again and pair the two devices. Put the puck into standby and after ten minutes check if pointing the control directly at the puck and IR wakes it up. It can't just be me.
I've just checked and the serial number on the replacement puck I received today is a fair bit under the one I received last week that I returned. I wonder if that might be why it's working, albeit only via IR. There is a difference of over 10,000 between the two numbers.
I'm not sure how many of these are made and sent out per week.
This message was authored by Jones_The_Cat This message was authored by: Jones_The_Cat
It's clearly another issue due to the mass produced nature of Sky Stream. They make thousands of these things and the remotes. Quality control is going to suffer at these kind of numbers.
The remotes have been flaky since day 1. I had three over the course of my year with Sky Stream. One died for no reason but was resurrected with the twisting method. Then died again. Another had intermittent periods of extreme fatigue where it would respond to a button press after about 3 seconds. Then died. The third started off fine but then seemed to get sluggish whilst it was receiving a firmware update via Bluetooth from the puck. It eventually settled down then started saying the batteries needed replacing constantly, even though they were brand new. Then it died too.
Then I gave up on Sky Stream. Cancelled the contract and sold my (customer owned) puck on eBay. Surprisingly people actually want to buy them.
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
@Kempston wrote:
@Jporch316
All the Stream pucks are loaned to customers with a lifetime warranty ( obviously whilst you are a subscriber) so if the investigation points to faulty hardware, and Sky are able to fix the issue they certainly would be replacing the faulty pucks under the warranty.
Sky Stream and Sky Broadband customer
This message was authored by Keef1969 This message was authored by: Keef1969
@Kempston I just did as you suggested and it 100% did NOT work.  It's as before, with Bluetooth on and paired it will NOT wake up my puck via IR - it was mm away from the IR receiver.  Unpair and then run on IR only and it works.
@Keef1969 that is odd. It's possible IR waking pucks on some devices and not others might be more a revision thing rather than a fault.
This message was authored by ZoeGP This message was authored by: ZoeGP
We have 2 new Sky Stream Puks and they don’t hold power
We have just joined the Sky Stream service and have 2 puks. There seems to be a problem with them as neither of them hold their connection to power, and seem unable to remain on standby. We have to disconnect power to reboot them every day, surely this isn't right? Thanks for any help or advice you can give.
Re: We have 2 new Sky Stream Puks and they don’t hold power
@GD1
sorry ... can you merge this with the main thread please 🙏
@Jporch316  Done
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
This message was authored by Zippy3 This message was authored by: Zippy3
This is getting VERY annoying.
As mentioned above I set up the remote into IR mode. Seemed to work, puck turn on and off but with the limitations of no volume or voice control.
Now the whole **bleep** thing has frozen. Remote dose nothing, doesn't light up, screen frozen.
If this kit is this fragile Sky can stick it somewhere dark.
Going to have to reboot and start again, AGAIN.
This message was authored by KATHREEVE This message was authored by: KATHREEVE
Sky puck not working
Sky puck not working in kitchen or the remote. Tried the numbers to reset etc and twisting the controller. Won't do anything
Locked
