Discussion topic: Sky Stream Puck to soundbar
This message was authored by: Capt555
Please advise menu settings...
Equipment
QLED 4K TV with HDMI eARC.
Sky Stream puck.
True Dolby Atmos Soundbar eARC (on its way).
Full sky package.
UHD/dolby atmos sky subscription.
I understand the physical setup.
Puck to HDMI in on soundbar
eARC HDMI out to TV eARC HDMI.
Could you advise which settings to use on the puck audio Menu in particular and the audio settings within the TV in general.
Many thanks,
Regards,
Re: Sky Stream Puck to soundbar
@Capt555  I have a Samsung TV and Soundbar with a stream puck.
My puck sound settings are :
Digital audio output HDMI = Auto
Digital audio delay HDMI = 0
I also have HDMI control set to ON in the start up & Standby menu
On my TV my sound settings are:
Sound Output - TV & Soundbar (through eARC)
Sound Mode = Surround
Expert/Advanced Settings are:
Woofer & Equaliser - I have left as default
HDMI-eARC mode = Auto
Digital Output audio format = Auto
Digital output audio delay = 100
Dolby Atmos = On
Sound feedback = Low
Simultaneous Optical Output = Off
I hope this helps 🤞
Avatar for Capt555
Level 2 icon
@Fothergill1
Thank you for taking the time to answer.
It's really helpful.
One more point, if I may. The TV settings would only affect the devices plugged straight into the TV, then using the eARC flow from the TV to the soundbar?
If I plug the Stream puck directly into the sound bar IN and then from the sound bar into the TV via HDMI eARC would any specific settings on the TV audio Menu be needed? Or switched off completely?
Regards
@Capt555 I'm not an audiophile by any stretch of the imagination and I don't really know the answer to your question.  All I can say is my setup works adequately for my TV viewing.
I have everything connected in what I believe is a fairly basic configuration.  Stream via USB to TV and Soundbar to eARC HDMI port.  I also have an Apple TV connected to another HDMI port.
Avatar for Capt555
Level 2 icon
Thanks again for your time and reply. It was really helpful.
