Discussion topic: Sky Stream - Network
This message was authored by: Simmo_UK
Morning,
I have recently made the switch from Sky Q to Sky Glass and Stream.
So far we are really enjoying the experience and wish we'd made the switch sooner.
We have 1 x Sky Glass and 4 x Sky Stream Pucks.
We have 900mbs Full Fibre, also provided by Sky
All devices are connected via Ethernet (direct back to router) with Wireless set to "off" Network Standby Mode set to "on" and Overnight Power Saving "off" on all devices.
Everything is working as expected with the exception of 1 Puck which almost every day when it is first turned on informs us it isn't connected to WiFi, on clicking settings it clearly says its connected via Ethernet and that WiFi is "off" on clicking OK it disappears and works as normal.
Is this just something I need to put up with, or do you think the puck is faulty and it's worth reporting to Sky to source a replacement Puck?
Re: Sky Stream - Network
Can you on the puck having trouble do a toggle of the puck wifi on/off, the standby off/on and overnight power saving on/off.
As soon  as you have made those changes, do a settings restart of the Puck.
We have seen that sometimes the options do not take correctly and do not get set, but doing a settings restart does set them.
I'm sure from what you mention that you are aware, but this is the settings restart.
Go to Settings>Systems Management>Resets & Updates
Select Restart device
Your Sky Stream puck will perform a reboot. It will take a few minutes to complete
Avatar for Simmo_UK
Level 2 icon
Thanks for the advice @lettice
I have just done that and restarted the device.
Will see how that goes over the coming days, fingers crossed that has done the trick
Avatar for Simmo_UK
Level 2 icon
Quick Update - Sky Stream puck turned on today (quicker than normal) and did not display the "WiFi not connected" screen.
So far so good but will continue to keep an eye on this.
Thanks again for your help
Avatar for Simmo_UK
Level 2 icon
Puck reverted back to the "No WiFi" again this morning.
Do you think it is worth a call to Sky to get the puck replaced, or is this something that we just need to put up with?
As per the original post, we don't see this behaviour on any of the other 3 pucks.
@Simmo_UK
Think it could be worth trying a replacement puck.
I've escalated this to Sky and they should be in touch with you soon about it.
Look out for a message from Sky on your email and Sky Community private messages.
Look out for the blue chat bubble within your Sky community.
More about an escalation here;
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Avatar for Simmo_UK
Level 2 icon
Appreciate it, thank you
Another thing you could try is swapping the Puck for a working one, just to see if the fault follows the Puck or stays in the location.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Avatar for Simmo_UK
Level 2 icon
Great suggestion, thank you.
I also had this thought and yes the problem followed the puck.
Just a quick update, I had a great online chat session with Sky Support yesterday (thanks again @lettice )  and we performed a full reset of the device as the next step.
Working OK this morning but like last time it took a few days to happen last time so keeping an eye on it.
This message was authored by: kimmy531
how do i reset a sky puck
