Discussion topic: Sky Stream 2 Remote
This message was authored by: BC1956
Sky Stream 2 Remote
Having searched the community for help with setting up a 2nd remote on 1 puck it was eveident quite a few people have had similar issues so I thought I would share my fix....... I saw advice for using BT on 1 remote and IR on the other I couldn't get this to work on my One For All remote. I got some more replies/help with this, as a result I bought a second Sky remote through Amazon (not cheap £30 and Sky don't sell them direct) with the intention of using one on BT and the other IR however the new/2nd puck worked straight out of the box without having to set it up or change it to IR. The only thing I had to set up was the connection with my SB. I can confirm all the button choices on both remotes work including voice control. For Info. I joined Sky 2 weeks ago so my kit is new.
Sky FF Gigafast / Sky WiFi Max / Sky Stream / 2 Pucks / Sky Ultimate TV / Sky Sports / Sky Cinema / Sky Whole Home / Sky Ad Skipping
