This discussion topic has been answered Discussion topic: Sky Sports Cricket UHD
Message posted on 11 Sep 2026 03:25 PM
Watching the Test match today I can't get a UHD channel on my Stream box for cricket. My friend who watches Sky via Virgin Media has the UHD channel. It seems that us native Sky customers are getting a raw deal. Or is there a way to access the Cricket in UHD on Sky Stream? I've tried all the usual methods to no avail. If there is no technical solution then surely Sky should be made aware and asked to fix it
Message posted on 11 Sep 2026 03:33 PM
When your on Sky Sports cricket press right that will give you the uhd feed
Message posted on 11 Sep 2026 03:27 PM - last edited: 11 Sep 2026 03:35 PM
Re: Sky Sports Cricket UHD
@GeoffWalton There is Sky Sports ME UHD but no Sky Sports Cricket UHD
Message posted on 11 Sep 2026 03:38 PM
Thanks for your reply. This is what I find. However it is available on UHD on virgin media. The ME channel is showing another sport. You used to be able to press the 3 dots button to get UHD or uae the 90x channel numbers to get the UHD version. But this seems to have stopped working.
Message posted on 11 Sep 2026 03:39 PM
Thanks that was very helpful and works ! Much appreciated
Message posted on 11 Sep 2026 03:42 PM
When your on the channel press right like you want to fast forward and you will see at the bottom of the screen watch from the start or watch in UHD press there and it will take you to the uhd feed
