Discussion topic: Sky Puck lagging
Message posted on 28 Aug 2025 09:32 PM
Sky Puck lagging
Absolutely fed up with the Sky Puck lag it's on every channel I have tried and reset WiFi turned on and off everything it asks you to do but still **bleep**! 💩
Message posted on 29 Aug 2025 03:17 PM
Sky to contact me
Please can someone from sky contact me with regards to my Sky Puck lagging and we have completed all the checks and even reset everything
Message posted on 29 Aug 2025 03:20 PM
Re: Sky to contact me
Hi @Samjo53 Unfortunately no one will contact you from a post on this public forum as we are customers like yourself. You will need to call Sky direct to discuss your issue.
Message posted on 29 Aug 2025 03:27 PM
I was sent here by Sky when I asked for help with Sky Puck.
I have managed to raise as issue but they are unable to check since 1.30am this morning!
Oh well kids will be happy 🤷♀️
Message posted on 29 Aug 2025 07:44 PM
Re: Sky Puck lagging
@Samjo53 wrote:Absolutely fed up with the Sky Puck lag it's on every channel I have tried and reset WiFi turned on and off everything it asks you to do but still **bleep**! 💩
Have you tried disabling the Wifi on the puck's settings, connecting via an ethernet cable and then rebooting the puck by turning it off at the plug for a couple of minutes? Its quite possible the cause of your issue is Wifi signal strength/stability
Message posted on 30 Aug 2025 10:58 PM
Message posted on 31 Aug 2025 07:52 AM
Have you tried testing with an Ethernet cable as previously suggested?
Message posted on 31 Aug 2025 09:43 AM
Do you have a number customers can use to call? I'm going round in circles trying to get my issue sorted and the virtual assistant is worse than useless
Message posted on 31 Aug 2025 02:47 PM
Where does it state has to be connected to Ethernet as my hun is another room from tv
Message posted on 31 Aug 2025 03:35 PM
@Samjo53 wrote:Where does it state has to be connected to Ethernet as my hun is another room from tv
Its doesn't HAVE to be connected via ethernet but an ethernet connection removes the instability of a Wifi connection ( and typically a number of issues people have is due to Wifi network related issues).
It doesn't matter if the router is in another room you can use powerline adapters to easily connect via ethernet cables.
Message posted on 31 Aug 2025 04:45 PM
@Samjo53 you appear to be posting on the same subject in multiple threads. The answers will be the same..
That is, it's most likely that poor wifi is the cause, of the problems you're having, as evidenced by the service checker results you posted elsewhere.
Message posted on 31 Aug 2025 04:48 PM
So the WiFi is not the service I am paying for and therefore also affecting my Puck.
I will be asking for compensation
Message posted on 31 Aug 2025 04:51 PM - last edited: 31 Aug 2025 04:52 PM
See: https://www.sky.com/help/articles/wall-to-wall-wifi-guarantee
It's a fairly slow speed that's guaranteed.
Message posted on 31 Aug 2025 04:54 PM
So not fit for purpose then if the WiFi does not meet the requirement speed!
Message posted on 31 Aug 2025 04:58 PM - last edited: 31 Aug 2025 04:59 PM
@Samjo53 wrote:So not fit for purpose then if the WiFi does not meet the requirement speed!
@Samjo53 , unfortunately, the strength and stability of a wifi network vary from property to property. There are many things that will cause interference with a Wifi network including other local wifi networks, the thickness of walls and floors in your property, and even things like the composition fo your property ( for instance if you have metal gurders in walls or floors the metal will block/weaken Wifi signals). Even things like radiators will weaken a Wifi signal.
As there are local factors like this, very few ISPs will necessarily be able to guarantee the strength and stability of the Wifi signal in your property to a great extent.
