Discussion topic: Sky Puck getting 1mbps, but same spot 76?
This message was authored by: C_field
Message posted on 18 Mar 2026 07:23 PM
Netflix says my puck is gettig 1mbps but my laptop next to it is getting 76mbps. Is this a dodgy puck? I've turned it on and off and reset everything... but just seems to keep dropping out.
This message was authored by: martswain
Message posted on 18 Mar 2026 08:04 PM
Re: Sky Puck getting 1mbps, but same spot 76?
If you have dual band router, most are, the puck and laptop may be connecting to different bands and the puck has a weaker signal and/or interference.
If you don't have a mesh WiFi setup, try splitting the SSIDs in the router menu and then connect the puck to the one with the best signal.
