Discussion topic: Sky FV and Netflix
Message posted on 24 May 2025 10:33 PM
Sky FV and Netflix
I thought I was paying £15 a month for Sky streaming and Netflix included. I didn't think I had to pay an extra £6.49 for Netflix?
Message posted on 24 May 2025 10:56 PM
Re: Sky FV and Netflix
That extra £6.49 sounds like the fee if you have upgraded the Netflix tier. The included tier with Sky is the basic with ads.
Message posted on 25 May 2025 07:18 AM
That £6.49 would be for the Netflix standard tier (without ads).
Go into your MySky account and look under Your Products>Manage content packs.
Select the Netflix tile and you will be able to downgrade to the free tier Netflix Standard with ads.
If you have moved from Sky Q or had a previous Netflix standard tier, it will have carried that tier over on moving to Sky Stream.
