Discussion topic: Sky Box not connecting to internet
This message was authored by: Girish55
My sky box stopped connecting to the internet/broadband today. Been working perfectly find up until this morning. Internet is working on other devices just not the TV. IP Address is not showing when going on to the network settings
Re: Sky Box not connecting to internet
@Girish55
Can you reset the settings, if not have you tried rebooting it at the mains ?
@Girish55 whst type of Sky box do you have out of Sky Q, Sky+HD or Sky Stream?
Avatar for Girish55
hi, i have the sky stream puck box. ive tried resetting everythying but nothing has solved the issue
Avatar for Girish55
hi, i have tried resetting and rebooting from the mains
Hi @Girish55 When I have had a similar problem in the past I find the following procedure always resolves the issue
Put your Glass or puck into Standby and then unplug both your puck and router.  Leave for a couple of minutes and then plug your router back in and wait for it to finish rebooting.  Once it has rebooted plug your glass TV back in and when that has also rebooted it should have reconnected to the internet
If that doesn't resolve the issue then have a look at the following link to see if it helps:
https://www.sky.com/help/articles/sky-glass-no-internet-connection-osm
