30 Sep 2023 08:39 AM
I plugged my stream box in to both connectors of my tv and a message said something about the HDMI. I've tried three different ways but still no channels. There is a light on the box and I pressed 1&3 as per instructions but nith8ng is happening. Any suggestions?
30 Sep 2023 09:16 AM
Do you see anything on your TV screen? Make sure you have selected the correct HDMI input using your TV's remote control, not the Stream remote, first of all.
30 Sep 2023 10:13 AM
Thank you. I've tried three different hdmi slots non have worked. I don't know what you mean when you say use my tv remote? To do what exactly?
30 Sep 2023 10:19 AM
To scroll through the inputs on your TV, have a read of the TV's user guide which explains how your TV works.
30 Sep 2023 11:12 AM
Ok thanks for that. I need to check it
