4
This discussion topic has been answered Discussion topic: Setting up 2nd sky stream puck box
This message was authored by: Fish271
I've recently changed to sky and have a sky stream puck box it set up perfectly downstairs but upstairs with the 2nd box it allows me to enter my WiFi password then it says continue setting up your channels brings up the blue sky logo then goes black then eventually comes back to your connected and just keeps going in a loop. I've tried both the HDMI 1 & 2 no joy, any ideas?
This message was authored by: mikealanr Answer
Re: Setting up 2nd sky stream puck box
Hi @Fish271
Try resetting the puck by pressing and hold the button on the bottom while powering it on as per the instructions on this article: https://www.sky.com/help/articles/setting-up-sky-glass-sky-logo
MikeAlanR
Hi @Fish271
MikeAlanR
Avatar for Fish271
Excellent thank you so much, I'll give that a go.
This message was authored by: Sharpie2
My new skystream box gets to software update & no further
This recently has been an issue for some customers on new setups of Sky pucks.
Have a read through this Sky help article.
https://www.sky.com/help/articles/setting-up-sky-glass-updating-software
If you can, just for the setup, do a power reset of the puck and attach an ethernet cable and  leave it attached for the Puck setup and see if that helps.
