Discussion topic: SKY PUCK NOT CONNECTED WITH TV
This message was authored by: Lija
My TV is not connected to Sky Puck and it's showing not programmed Kindly help with this issue
Re: SKY PUCK NOT CONNECTED WITH TV
That's usually a message from the internal television tuner, not a Sky box.  You may need to use the TV remote to select the correct HDMI port.
@Lija  I agree with @TimmyBGood  thats not a Stream puck message but your TV, use the remote to cycle through the inputs to fin  the one the puck uses.
