Discussion topic: Replacing batteries in stream remote on a weekly basis
Message posted on 09 Jan 2024 10:50 PM
For the last 3 months I am having to replace the batteries in my stream remote weekly, downstairs isn't too bad, maybe monthly, but upstairs is weekly, that's not right surely
Message posted on 09 Jan 2024 10:59 PM
Re: Replacing batteries in stream remote on a weekly basis
@Paulb361 This is a fairly common problem. I had the same thing but in my case they lasted about 3 weeks so I was a little better off than you are. I contacted Sky and they sent me a replacement remote which has resolved the issue.
You can request a replacement at the following link: Streaming TV replacement remote
If you have one available you can also use a Sky Q remote. I use one as a spare.
Message posted on 10 Jan 2024 11:14 AM
Sky Q remotes should've been returned to Sky🤔
Message posted on 10 Jan 2024 03:22 PM - last edited: 10 Jan 2024 04:50 PM
@Exiled-in-HH Only one needs to be returned. I had 2 so that both my wife and I had a remote (obviously one on buetooth and the other on IR). It was purchased on Amazon about 5 years ago and unlike the Glass/Stream remotes it still works perfectly.
