Discussion topic: Replacement puck cable
Message posted on 17 Jul 2025 01:22 PM
Hi
would I be able to receive a replacement pick cable please?
kindest regards
Message posted on 17 Jul 2025 01:35 PM
Re: Replacement puck cable
@JudeFeh If you're referring to the power cable you'll need to call Sky to send a replacement puck as SKy don;'t have spare parts.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Message posted on 17 Jul 2025 04:27 PM
If you mean a HDMI cable, you'll need to buy one. They're wildly available and you just need to buy a HDMI 2.0 cable, they may also be described as HDMI UHD or 4k
Message posted on 17 Jul 2025 06:32 PM - last edited: 17 Jul 2025 06:33 PM
@JudeFeh wrote:Hi
kindest regards
Hi @JudeFeh
@see link below for sky spare parts - it does say official spares are available on eBay
https://www.sky.com/help/articles/order-sky-glass-accessories
