Discussion topic: Replacement Sky puck
Message posted on 07 Apr 2026 07:47 AM
Hi,
I am experiencing continuous connectivity issues with my SKY puck.
please can I get a replacement?
Message posted on 07 Apr 2026 07:49 AM
Re: Replacement Sky puck
@ClintVosloo replacing the puck is very unlikely to make a difference if the issue is poor WiFi in the area where the puck is placed. You can easily see the WiFi signal strength by going to the Network tab in the settings menu.
Message posted on 07 Apr 2026 11:29 AM
Also, if you open Netflix on the puck and go to Help -> Check Network, you can run a diagnostic from the puck, which will tell you the download speed the puck is currently getting.
