3
This discussion topic has been answered Discussion topic: Replacement Sky Stream - odd ip behaviour
This message was authored by: Dshepherd
We recently had a replacement Sky Stream Puck. All good except my router is showing it as having 2 ip addresses. This device is only connected via wifi, no ethernet cable. One address is valid for my network the other address is ...
100.64.11.1
Any thoughts here ?
David
Avatar for Dshepherd
Level 2 icon
This message was authored by: Dshepherd Answer
Re: Replacement Sky Stream - odd ip behaviour
Thank you for the responses. My eeros ere due a patch so the network was restarted. Now I have only the correct address showing. One of life's mysteries....
Anyone else using eero's with sky stream? Any issues?
Many thanks
David
This message was authored by: Jporch316
100.64.11.1
Any thoughts here ?
David
Your router is not reserving an address for the previous sky puck ? Powering off your router for 30 mins or so (depending on your isp) might release / renew the ip addresses if it is
@Dshepherd wrote:
100.64.11.1
100.64.x.x/10 is a rather peculiar netblock used by ISPs for CGNAT: technically it isn't actually valid for either the internet or a LAN.
Personally I'd suspect that's just a weird glitch caused by something your ISP is doing.
Level 2 icon
Many thanks
David
