3
This discussion topic has been answered Discussion topic: Remote
This message was authored by: Susan72
Remote
Hi my sky remote has stopped working and I would like a new one sent please
This message was authored by: MarkGoldsmith Answer
Re: Remote
Check the batteries
An easy way to check is to cover the buttons slightly on your Sky remote with your hand. You should see a white backlight behind the buttons. If you don't see the backlight the issue is the power with the remote, so potentially a battery issue.
Check the battery compartment to make sure the paper used to protect the battery has been fully removed. It might have ripped when being removed leaving some behind.
Still can't see the backlight? It’s likely you need to replace the two AAA batteries.
Re-Pair the remote
Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
Press 1 and 3 together for three seconds (bluetooth mode) and follow any on-screen instructions.
The next option sounds insane but a number of users have reported it resolving the issue with their remotes. You could try holding the remote at both ends and giving it a gentle twist as though you were wringing out a towel. It
If it is still not working have a look at the following guides:
https://www.sky.com/help/articles/remote-control-help-sky-glass
https://www.sky.com/help/home/sky-tv/sky-tv-glass/fixing-a-problem-sky-glass/fixing-sky-glass-remote...
If none of these options work you can request a replacement remote via this link: https://www.sky.com/help/forms/streaming-tv-remote
If you have an old Sky Q remote, you can use that as an interim solution whilst you await the new remote.
Avatar for Susan72
Level 0 icon
Re: Remote
Can you help me with this issue
Re: Remote
Check the batteries
Re-Pair the remote
This message was authored by: Kieran7676
Re: Remote
Mine didn't work on arrival - tried different sets of batteries and no joy.
I got a thin nail and at the end of the 2 battery  groves, gently pulled the spring centres out a little. Turns out they weren't meeting the battery terminals well. Been fine ever since
