Discussion topic: Remote controller is never switched on
This message was authored by: AH77
I received a new skybox and remote controller today.  A remote is never switched on so cannot input WiFi password. I think this means Skybox is useless. Is there any other way than cancelling service?
This message was authored by: peter-marlow+1966
Re: Remote controller is never switched on
Have you made sure all the paper  tab that was in the battery  compartment  is out, take the back off the remote  control  and check and possible  change  the batteries  to they may be dead
P c marlow
This message was authored by: Stephen+Mourton
@AH77   When you say the remote is never switched on, what makes you think that?  The Stream remote doesn't really have anything on it that indicates it is working unlike say the Sky Q remote
