Discussion topic: Re: Sky stream
Message posted on 22 Aug 2026 10:41 AM
Re: Sky stream
Stream does appear to use quiet a lot of band width.
My system is quite simple simple, TV plus 4-5 ithings on most of the time, the TV is a Q Box and my Broadband is an entry level full fibre connection.
It all works seemlessly and given the issues that can arise I am reluctant to tinker. Would replacing the Q box with stream be possible should I try to give it a go?
Message posted on 22 Aug 2026 10:52 AM
Re: Sky stream
@Lucyliu2 Sky Stream works over broadband.
Minimum recommended broadband speeds apply and might change depending on your package.
You may need faster speeds to get the best experience. Especially when watching in UHD or streaming on more devices at the same time with the Whole Home pack. For more info, see Broadband speeds explained. Sky also recommend a fibre broadband connection.
If you’re with another broadband provider, we recommend you check your broadband speeds with them.
Recommended minimum broadband speed of 25Mbps. Or 30Mbps if you add an extra Sky Stream puck or to watch in UHD.
It also important to note strong stable wifi is equally as important to your line speed.
