Discussion topic: Re: Puck says poor connection
This message was authored by: Bexjayne1971
My puck says poor connection but the speed test is fine. How do I clear the status as I've already booted the puck
This message was authored by: Dazzasky
You can't, if the puck is working as expected then I wouldn't worry about it. I have this showing on all my pucks when I use them all the time and yet my pucks work perfectly fine without issue @Bexjayne1971
