Discussion topic: Re: Problem with SKY Go
This message was authored by: Chippan69
My sky puck has nothing can't connect to internet. It's a wired connection and we are using the internet as always
This message was authored by: Stephen+Mourton
@Chippan69  I presume you are referring to Sky Stream not Sky Go?
If you can talk us through what is happening that would help and we may be able to advice you.
Avatar for Chippan69
My stream dies every day, and needs restarting but today it took 4 hours of regular testing to get a connection.
i gave up in the WiFi connection as it never picked up the WiFi, so got a WiFi extender behind the unit and plugged it in.
I just can't seem to get a fluid and stable connection.
You need to try connecting the stream puck to the router via a Ethernet connection
This message was authored by: elinormcb
No not Sky stream - Sky Go
Sky Go isn't available on the Sky stream puck.
